ChrisDR
I have tried searching all over google but I can't seem to find the info that I am looking for.
I was pulling out of a parking spot the other night and started experiencing a banging whose frequency increased with RPMs. I immediately thought it was a driveline issue. I parked it for the night and the next day I jacked it up from the rear and hand spun the wheels so I could examine the driveshaft.
Sure enough, I saw one of the metal straps at the driveshaft-pinion flange joint dangling and as the driveshaft spun, it contacted the driveshaft tunnel. Upon further inspection, 3 of the bolts had managed to work themselves loose (there didn't appear to be any loctite on the threads) and one bolt had broken off in the pinion flange.
I realize that these bolts are hardened steel so I don't know if I can drill the bolt and use an ez-out. How should I go about removing this bolt?
I also haven't been able to find a replacement for the bolts. I went to Ford but the parts guy couldn't find just the bolts and assumed that they could only be purchased as a part of the assembly.
Anyone have any insight?
Thanks,
Chris
Thanks,
Chris
