Lately, I've been experiencing a bucking or extreme hesitation problem. When this occurs, the gas pedal goes limp for an instant, the engine almost sounds like it stops turning, and there is an abrupt stop to exhaust noise. This all lasts for roughly a quarter of a second, then drives like normal again.
There is no belt issue that I can see. It always does this at normal speeds, while the car is in motion. There are no codes thrown whatsoever. The engine never bucks or acts oddly when the car is idling and this occurs no more or less frequently based on air temp, engine temp, and driving tendencies(aggressive vs not).
My question is two-fold. What could be the culprit?
And secondly, could my estimation of what it is, be causing it:
When I installed my 4.10 gears, the backlash, I believe was on the high side of the factory specs, but still within those specs. However, since the install, 2-3 years ago, I have had a gear whine on deceleration. Could the gears be wearing out prematurely, and binding at certain points, causing intermittent jerking like I'm experiencing?
I have not drained the fluid to check to shavings or quite possibly in my case, if this is it, chunks of metal, but wanted to see if something like that could cause my problems before I did. I do have the original 3.55s that I can (reluctantly) put back in, but don't want to without being sure what's wrong.
BTW, the engine is built with eagle internals at stock bore/stroke, running a techco blower at 10#.
