Might want to make sure it's not like my block. This is just inside the pan rail. There are super-sharp aluminum slivers like this all over. The one in the picture flaked right off when I pushed on it.
This is the front of the block, back of the oil pump. It is the main feed hole up to the filter housing. The block return from the housing is a larger hole, bored smooth to the center of the block. Not sure that oil flowing over a restriction of cast-in numbers and letters is ideal.
Needless to say this block will be getting the full internal deburring treatment and the oil feed passage will be reworked. I have no idea if they are all like this or if mine skipped a step on assembly. The main bearings looked brand new with over 30,000 supercharged miles- the filter must have caught all the slivers that got sucked up. Explains the light scoring in the oil pump.
Just an FYI!
Just an FYI!
