Camber is easy to do:
"crash bolts" skinny bolt with an eccentric lobe to adjust the strut to knuckle angle, thus adjusting camber
"camber plate" replaces the crap Ford upper strut bearing plate, allows the top of the strut to move inboard/outboard relative to the tower, thus adjusting camber
Caster is a bit more problematic... Only one that I know of is the Maximum Motorsports camber/caster plate, allows strut-top to move inboard/outboard as well as a slight (around 1*) fore/aft. Nice piece, I have one myself.
Also, just as an aside, due to the geometry of the front end, changing camber will have a small effect on toe, but not that pronounced. If you have a toe issue, it will show up as "sawtooth wear" across the tread of the tire: look for a sharp edge to the inboard or outboard of each tread block on the tire Wearing the inside or outside edge will come from camber being off, wearing BOTH is underinflation. Caster will not show in wear, but will show with a pull to one side or the other. Cupping will indicate bad shocks or a wheel badly out of balance.
Both tires have a fairly narrow wear pattern around the entire circumference of the tire about 1/2 inch wide, no cupping, no pulling.
