Nov 17, 2011 #1 dgann3 forum member Joined Jun 8, 2011 Posts 532 Reaction score 0 Location Lafayette, TN Where to find a key for this locking lugnut? Sent from my iPhone using Tapatalk Attachments ImageUploadedByTapatalk1321576626.317999.jpg 30.5 KB · Views: 32
Nov 17, 2011 #2 Wicked GT OCD with ADD... Joined Apr 24, 2011 Posts 7,487 Reaction score 4 Location Omaha, NE That almost looks like a Torx Bit?
Nov 17, 2011 #3 dgann3 forum member Joined Jun 8, 2011 Posts 532 Reaction score 0 Location Lafayette, TN Thats what I thought. I've never seen anything like this one
Nov 17, 2011 #4 3VPOWA Senior Member S197 Team Member Joined Sep 4, 2009 Posts 2,096 Reaction score 4 Location East Texas My friend who recently puchased an early 90's model 240sx had those same lug nuts on the wheels. I'll try to see if I can find out what they are. EDIT: The key looks like this: DORMAN Part # 711425 Tuner; Size; M12-1.25 LOCK SET-TUNER (4 locks/1 key;: M12-1.25; Chrome) Last edited: Nov 17, 2011
Nov 17, 2011 #5 dgann3 forum member Joined Jun 8, 2011 Posts 532 Reaction score 0 Location Lafayette, TN That helps a ton. Thank you very much!
Nov 17, 2011 #6 3VPOWA Senior Member S197 Team Member Joined Sep 4, 2009 Posts 2,096 Reaction score 4 Location East Texas dgann3 said: That helps a ton. Thank you very much! Click to expand... No problem. There are different sizes for those type of lug nuts, so I'm not sure what kind you'd need.
Nov 17, 2011 #7 skwerl tree hugger Joined Aug 6, 2011 Posts 16,199 Reaction score 1,147 Location central Florida I recently bought a set of Torx bits on Amazon that go up to 60mm. I needed the 47mm to drop the gas tank on the Mustang. There are larger sizes available. Determining the size will be the biggest hurdle.
Nov 17, 2011 #8 dgann3 forum member Joined Jun 8, 2011 Posts 532 Reaction score 0 Location Lafayette, TN Yeah I'll have to go count the points on it to see which one....Maybe I can borrow one from somebody and then ditch those lugnuts
Nov 17, 2011 #9 tjm73 of Omicron Persei 8 S197 Team Member Joined Jun 9, 2010 Posts 12,092 Reaction score 1,638 Location Rush, NY Tack weld a bolt to it that touches all the points and remove the bolt/lug. Throw in garbage.
