chon
Must install Paxton soon!
Anyone have some recommendations on some nice claybar that is easy on the paint and not ridiculous on price? Been using Adams claybar, stuff is really hard to work with.
I've been using this, speeds up the process big time.
http://www.detailersclub.com/store/pc/Speedy-Surface-Prep-Dx-Pad-Fine-Grade-31p212.htm
This FTW!!!!!! I used this with CG luber and my PC. Did the whole car in 20 minutes!!! Stuff is magic!!!
I've used the McGuiars kclay bar kit several times with good results
Now thats interesting. How well does it work? I have been using the mcguires claybar with chemical guys clay lube.
I just bought a similiar product, Nanoskin Autoscrub and it works pretty well. I bought the fine grade. Might not pull of your serious contaminants as well as a normal clay but makes the process much easier/quicker.
That's awesome. Do u guys see this being safe for black. I see both of u have black cars and I would love to use this instead of clay. What does the surface feel like?
Just used a Mother's claybar that I had sitting around. Started the process after removing some Plasti-Dip. Noticed that there was substantial overspray that wouldn't come off. It worked OK, but took quite a bit of work. I will be looking for something to replace it shortly.
What is the consensus on Pinnacle stuff? Found a nice kit for under $30.
Surface feels just as smooth as if you used a clay bar. I used the pad twice in the last 12 months. Most important thing to remember is to keep the pad and paint lubricated. I think I had my Flex set at 1 to 2.
