cluster question
5.SLOW
missouri
ok i bought a cluster from a memeber on here and works fine but got couple question on difference.
i notice the one i took out had abs on it and one i put in didnt, one question is will it mess with brakes and would this have anything to do with the tcs to cause it dont turn off now?
other i notice the one i took out didnt have or didnt work low tire lite and one i put in does and stays on but it will cause the wheels dont have the sensors?
oh this is a 05 auto
tungstenpony
Did you go to the dealer and get your info swapped from your old cluster into your new one? If you don't then you will have problems like your mentioning. Abs lights on tpms lights on ect because the cluster is looking for the things the only car had not yours. The dealer will charge 100$ for this normally but you will have to put your old one in so they can pull the data them swap it so they can upload it to the new.
