Gruca
World's Slowest 3v Owner
So I'm debating on the Comp Cam 127300 but they recommend a 3.90 gear. I have a 3.73 already in the car, is that going to make that big of a difference that I should choose a different cam?
The biggest reason I've found in gear recommendation is compensating for low rpm powerband shift and the gear helps for streetability (less bucking). However, most tuners are sharp enough to compensate for taller gears with cams. If you like 3.73's then keep them. Everyone told me to run 4.10 or 4.30 gears when I picked a centri for my power adder, but the way I drive and the conditions I drive in, 3.73's are spot on perfect. I ran 4.10's with the comp 127020 cams, it really does help get into the powerband faster, but there's alot more shifting and if you like to cruise around 80mph you better love your exhaust tone around 2800rpm lol.
I did a ton of research on the 300's and 350's. Nobody says they lost any bottom end.
