It's that time! We've gotten literally hundreds of inquiries about the 2011 & 2012 5.0L Coyote Mustang cams. The wait is finally over! They're in-stock and shipping. Can't wait to bolt these up to our 2011 Automatic to see what it'll do to our current 10.43 @ 130mph. We'll have dyno results and more soon!
Want some specs on them in the mean time?
Comp Cams Stage 1 XFI NSR Camshafts (11-12 GT / 5.0L Coyote)
• Advertised Duration: 267
• Valve Lift Int: .492
• Valve Lift Exh: .453
• Duration @ .050 Int: 220
• Duration @ .050 Exh: 223
• Lobe Separation: 126
• RPM Operating Range: 1500 to 6800
Comp Cams Stage 2 XFI NSR Camshafts (11-12 GT / 5.0L Coyote)
• Advertised Duration: 275
• Duration @ .050 Int: 228
• Duration @ .050 Exh: 231
• RPM Operating Range: 1700 to 7000
Comp Cams Stage 3 XFI NSR Camshafts (11-12 GT / 5.0L Coyote)
• Advertised Duration: 283
• Duration @ .050 Int: 236
• Duration @ .050 Exh: 239
• RPM Operating Range: 1900 to 7200
None of these are spring required cams, however ALL OF THEM need the phaser limiter kit, which we'll have up on the site soon.
Stage 1 & Stage 2 Cams are compatible with stock gears and stock converter, while the Stage 3 cams need a 3.73 or steeper rear gear ratio and long tubes. Converter will probably be a good idea in Stage 3 as well, but we'll know for sure once we install them in ours!
