Bobby
turbo gt about to go fast
These are complete fuel systems from S&H Performance and can be customized to almost anything you need. shipping not included. all upgrades are at the bottom.
S197-S 3V Level 1 Returnless System $900.00
Simple and cost effective pump. Ford GT Supercar pumps work seemlessly with the OEM control system
INCLUDES
INCLUDES
750-800 rwhp capable returnless fuel system with simple and effective hose routing. The feed line input to the front of the driver side rail and crosses over behind the motor.
INCLUDES
1200 rwhp capable return fuel system made with top shelf components. The feed line enters our F4i regulator, then distribution lines feed to the rear of both fuel rails.
INCLUDES
1000cc injectors for $200.00
80lb injectors $50.00
fuel pressure gauge $25.00
boost/vaccume manifold kit $75.00
465 pumps $100.00 (return style only)
fc3 controller $40.00
-10an feed upgrade $90.00
stainless steel reusable filter $30.00
billet mounting bracket for fuel filter $40.00
INCLUDES
- S197-S Fuel Module
- Dual GT Supercar Fuel Pumps
- OEM Feed Line Adapter Kit (includes feed adapter and plug)
- 60lbs injectors (upgrade to 1000cc injectors for $200.00, 80lbs injectors for $50.00)
- fuel system wire upgrade
INCLUDES
- Returnless fuel line and filter upgrade ( hat to rail)
INCLUDES
- S197-S Fuel Hat
- passenger side and driver side fuel rails (black or clear)
- GT500 Billet Fuel Rails
- F10 Inline Fuel Filter
- All fittings, hose, and hardware necessary to complete typical fuel line plumbing
-Aeroquip Kevlar/Nomex -8 Fuel Line (one 15' section for feed and xover)
-Qty 3, low profile 90 degree -8 AN to -8 o-ring fittings
-Qty 2, -8 AN to -10 o-ring fittings
-Qty 1, low profile 180 degree -8 o-ring/female to -8 o-ring/male fitting
-Qty 2, -8 o-ring plugs
-Qty 1, -8 AN to -8 o-ring fittings
-Qty 5, -8 hose straps with stainless mounting screws
-Qty 6, -8 hose ends
-Qty 2, 1/8 NPT plugs
-6mL Loctite 567 - 60lbs injectors (upgrade to 1000cc injectors for $200.00, 80lbs injectors for $50.00)
- fuel pump wire upgrade
INCLUDES
- S197-S Fuel Hat with Viton upgrade
- driver and passenger side fuel rails (black or clear)
- Dual DCSS405 Fuel Pumps
- F4i Fuel Pressure Regulator
- s197fc2 controller Billet Fuel Rails
- F10 Inline Fuel Filter with Viton upgrade
- All fittings, hose and hardware necessary to complete typical fuel line plumbing
-Aeroquip -8 Kevlar/Nomex Fuel Line (two 15' sections for feed, distribution, and return lines)
-Qty 4, low profile 90 degree -8 AN to -8 o-ring fittings
-Qty 5, -8 AN to -10 o-ring fittings
-Qty 3, -8 o-ring plug
-Qty 10, -8 hose straps with stainless mounting screws
-Qty 9, -8 hose ends, straight
-Qty 1, -8 hose end, 90 degrees
-Qty 1, 1/8 NPT plug
-0-100 psi Fuel Pressure Gauge
- fc2 controller
