loots06
I am getting ready to for a budget short block build and will running slightly higher compression. My build will consist of Wiseco piston 9.5:1, .020 over, Boss connecting rods with a stock 4.6 crankshaft. I know there are several forum members that are running higher compression ratios and boost using various blowers or turbo set ups. While I was speaking with a sales representative and preparing to order the pistons they actually encouraged me to go with a lower compression ratio. They simply explained that higher compression and boost does not work well. I explained that the new 5.0 has a higher compression and that Whipple makes a blower kit for the car which produces tons of power. I didn’t understand their argument and really thought that low compression and higher boost was an old school thought given the numerous documented successful builds out there, several of which have been well documented on this forum.
Does running a different type of power adder such as positive a positive displacement or centrifugal blower really matter when it comes to a higher compression set-up? They thought it did given that one is instant while the other builds boost. A turbo set-up is obviously different and seems to make a ton of power. Is there huge difference in the amount of power a high compression motor will make using a different power adder? I would image the power would be more linear but nothing more. Any how let me know what power adder you running, compression ratio, amount of boost and of course the total power your combo makes. I never ordered the pistons but will over the weekend. Maybe I'll should look at a different vendor!
