Convertible rear end links loose
jmustang
18mm rear sway bar endlinks we’re so loose I could move them laterally by hand while the car was parked. I replaced the worn rubber bushings with prothane bushings thinking that would solve the problem but I can still move them by hand!
When driving hpde I can hear clunking from the rear end which I assume is the end links sliding around during load transfer in corners.
I need a better solution as the clunk drives me crazy. Any better solutions for the convertible?
nawagner
IA
Don't think the rear endlinks are different on a vert. Been a while since I've been under mine though. Have you replaced the upper control arm? If so there are some that are notorious for using holes that are too big and you get clunking.
Racer47
Doesn't have much to say
SE Wis
The vert bar is the same as all the rest. I think nawagner is right. Check the 3 main links.
