Convertible window short drop issue.
scrappydoo1888
Ottawa Canada
Hi guys,
My battery died the other day and I recharged it fully after replacing the plugs and oil. My issue now is that my front windows in my 2005 Mustang GT convertible go up and down fine. It is when I open the door the window does the short drop quickly but then goes right back up before I can close the door in time which will cause damage to my window or top. The other weird thing is that while I was trying to troubleshoot this the door open chime would turn off or after I take the key out the radio still plays which has never occurred before. I tried disconnecting the battery then opening and closing the window with the 2 second delay tactic but that hasn't worked.
Does anyone have any other suggestions?
Try the window reset procedure in the manual?
Try the proper reset procedure like stated. And inspect for water intrusion at the SJB, my windows were acting up like that when I had water on the back of the sjb from the cowl drain.
