Couldn't pass up it up....
richman
WTF!!! AGAIN AMERICA?
Michigan
SO..bought my first truck. I needed a truck for my new job so I shopped around and found this for a steal. I wanted an f150 and that was all I was looking for..but came across this that a contractor was giving up.
So... it's a 2002 2500HD with a 6.0.. I really don't know much about chevys but I will be doing my homework on it. From the people who have had trucks like this, what should i be worried about or replace asap.?. He has had the fuel pump assembly replaced a few months ago along with plugs, wires and a few other odd things from what I seen it is in good shape and should be a good work truck.
GOTTORQ
Connecticut
Mostly electrical issues, I have a 2003 trailblazer. My speedometer gauge shit the bed, they replaced my gauge cluster, another common problem is the gas gauge going. I have had issues with wheel bearings same one has gone twice on me, my power driver seat has decided to work when it wants to. ABS sensor on transfer case has gone bad. I think that's it lol.
richman
Michigan
wow..thanks. I bought this truck becuase it's simple.. 2wd manual everything except powersteering obviously.. no leaks and good service history.. ill look into the electrical issues though. thanks
weather man
Persistance Is A Bitch
MN
The truck looks good. The old saying "if it looks like a duck, it probably is" holds some truth. When you buy a 11 year old truck, not a bad idea to replace every single fluid. That way you know they are fresh and don't have to wonder if they got changed. That includes flushing the brake lines.
richman
Michigan
yeah I'll change the fluids and do a lot of maint. that should be done. hoping I'll keep this thing for a wile. are these engines hard to come by anyways? if or when I need one?
Fallenauthority
La Plata, MD
You won't need one. The 6.0 is pretty much bulletproof.
weather man
MN
GM is still running the 6.0 in the 3/4 ton.
richman
Michigan
good to hear!!! really good to hear
Sent from my SCH-I510 using Tapatalk 2
richman
Michigan
took the first real drive today.. sounds like it's got a small exhuast leak from a hole behind the manifold. other than that its one solid ride. anyone know of a good place to get used parts for these? I tried craigslist already..Nothing in my area
AbdullaGT500
Little Rock, AR
We've been dealing with GM trucks and SUV's for years, most common issues that we see:
-Stepper motors in the instrument cluster gone bad
-Fuel pump gone bad
-Transmission gone bad
Otherwise, we rarely see any major problems even with a ton of miles.
richman
Michigan
-Fuel pump gone bad
thanks..yeah the cluster is slow to respond so that may be in my near future as well.....
richman
Michigan
awesome...ill be picking one of those up....
JEWC_Motorsports
S197 Junkie
Texas
I wouldn't call the 6.0 bulletproof. Read up on the rockers. They like to come apart and the needle bearings will fall into the oil pan. That goes for any lsx engine.
quiksilver15
Houston
The only issues I've ever seen with the rockers are after a cam swap with high lift, even then most don't ever swap them. The LQ4 is a great motor with few to no problems when maintained. The truck has 4L80e transmission, they are pretty bullet proof. The 60e trans is the one that blows alot. If you don't feel confident in repairing you own cluster there are a few companies on ebay that will repair yours for cheap. I've had several LSx powered trucks, if you have any questions lemme know.
richman
Michigan
alright!! so all the chevy forums suck balls compared to this one. going to get some exhaust manifolds because the passanger side is leaking.. so the cast iron ones are supper cheep but they have short headers as well that are cheep as well. who has done the repair and what should I replace wile I'm under there?
Fallenauthority
La Plata, MD
Have you actually inspected the manifold on the car now? More than likely it broke an exhaust stud on the rear of the head, fairly common problem and a real pain in the ass to extract the old one.
richman
Michigan
no I just started the engine and felt for the leak. It's pretty large exhaust leak. Though I will jack the front end up and verify. So if it's a broken bolt then what? Drill it out and tap a new hole with threads? Man that sounds like a big pain in my ass
Fallenauthority
La Plata, MD
You would have to drill and extract the old stud. As long as you have a good set of bits and extraction set it shouldnt be too bad, the worst part will be trying to get up in there to get a drill in there.
