Alright!!!.....
So I've been working for a month with this truck and have a list of things that need attention.. I'm not suprised because of the miles and year of the truck. Overall I really like this truck.. It pulls pretty hard and so far is real dependable. Here is what I have..
-- Passenger side manifold is cracked and yes there is a bolt missing as well...
-- Drivers side upper ball joint/passenger side lower ball joint need to be replaced
-- Powersteering pump looks to be leaking..
-- Drivers door doesn't shut completely..? Which leaves a space for weather to come into cab. I'm pretty sure its the latch..but we will see
-- Driver side back door latch broken
-- Oil pan is leaking
-- air/heat doesn't come out front facing vents..so? maybe a blendor motor/actuator?
-- maybe a rear main seal leak but can't tell because of oil pan leaking..no transmission fluid lose as I can tell..
-- Driver's seat foam is all but gone.. I knew this. I just need to find a used one and put it in.
-- windshield is cracked(no big deal) but it leaks water when it rains or when i wash it..?
-- serpentine belt is cracked(easy fix)
So far that's about it. I am going to tackle these over the next few weeks or longer depending on time off. Any input or tips would be great. thanks
