So I just purchased my M-6004-463v timing chain/tensioner/phaser kit from Jegs and had a couple of questions. I saw a crank positioning tool and another little unit to lock the camshaft phaser in place. Are those tools really necessary?
I know the cams will want to rotate when the chain gets removed. I was either going to lock it in place with vice grips on the actual shaft of the camshaft or I was going to relieve the follower tension on the lobes by loosening the cam caps. Is there a preferred method? I was thinking of removing the culprit followers too but I don't have a 3-valve spring compressor.
Also, with all of that taken apart, should I be looking at an oil pump upgrade also? I've never had any pressure issues and she still flows pretty good.
