Custom Sub Boxes
bigwilly43729
I do stupid shit, a lot
Oklahoma: Not terrible
Those subs will probably fit, but you are definitely going to have to go with a fiberglass box in the spare tire well and you still may not have enough airspace for both of them.
Time to break out the packing peanuts, lol.
BadHabit2Break
Houston, TX
Its all about trial and error, thats how you learn
Thats true....but when it comes to custom box building....I usually like to do it right the first time.
Since you have Kickers.....try here first.
http://www.kicker.com/box_building
Depending on YOUR sound likings......THIS IS FOR A SINGLE SUB
Sealed - 1.25 cuft.
Sealed SQ - 2 cuft.
Vented - 1.75cuft, Square port 2.5x13.25x22.5
Vented SQ - 3.25 cuft, Square port 3x13.25x14.5
Lupo222
Fort Lauderdale, FL
So if I wanted to add just 1 10" sub, low pro (small magnet), would the tire well be big enough to house this? I'm getting sick of my stock sound as well and would like to add a little bump
eddieval5
katy,texas
I'm planning on building two boxes out of fiberglass and MDF for some 10's one each on either side of the trunk. So I still have the majority of the trunk to use but still having the bass from the subs.
Mustang30212
Columbus, Ga.
Several companies make sub boxes that fit on the right side up inside the rear fender area.
RH
Memphis 05
Just make sure that your box is correct to the box requirements or your efforts will be wasted. Wrong box = blown sub or bad sound....
Good luck.
Mustang30212
Columbus, Ga.
I am aware of the Zenclosures box, and the JL & Kicker preloaded boxes. Are there others?
MTX makes them as well as Saleen.
I have one of the Saleen boxes with a single 10" with built in amp. It's not over the top and it's a simple plug and play.
RH
speedfreak1000
2 sided tape expert
Springfield KY
Jeffk
Thomasville, NC
Mustang30212
Columbus, Ga.
Is it just me or is that way too much for a box..... I have been looking to get one to fit in that same spot but just cant convince myself to pay so much money for some wood.
For a custom fiberglass box....doesn't sound to far out of range.
RH
kylecm85
Lexington, KY
That is about average. Fiberglass gets expensive. But it being carpeted they could sell it for cheaper if they chose to. If it was painted. It would be well worth that price.
