Cut off while driving and won't start back.
Discussion in '2005+ Ford Mustang v6 4.0L Tech' started by MDred, Aug 2, 2017.
  1. MSgt46270
    MSgt46270 Senior Member
    6,053
    15
    Apr 6, 2007
    San Diego, CA
    This reminds me when my 2005 GT broke down with no warning. Had it towed to the dealer and they told me I ran out of gas, but the gas gauge was should gas in the tank. The float in the gas tank was replaced and problem fixed.
    I have no idea on how to help you, best of luck.
  2. Mirage
    Mirage Junior Member
    May 6, 2017
    Unfortunately, Ford had a better idea, and deleted the schreader (sp?) valve from the fuel rail on the '05 and up models. Sucks. I bought a block and gauge that mounts between the fuel rail and the Fuel Rail Pressure/Temp Sensor for like $50 on eBay. ( check here : http://www.ebay.com/itm/Metco-MFF00...ash=item489920fe0b:g:atUAAOSwx6pYqni3&vxp=mtr)
    You can find a 1/4" 0-100psi gauge anywhere.
  3. 07gts197
    07gts197 forum member
    460
    Feb 5, 2015
    Naples, Fl
    If the throttle body isnt opening no air will get into the combustion chambers. These motors dont use iac's because the throttle body does the work of one. When the car is off the tb is closed. You can verify this by pulling the intake tubing and turning the key on to see if the throttle opens at all. Its possible the throttle body motor is dead but I have yet to see that happen. Do that along with the test stated above about pulling the plugs after cranking.
    It still could be anti theft though, good call. Op is the theft light flashing?
  4. MDred
    MDred Junior Member
    21
    Aug 5, 2015
    Hi all! Well after checking and finding the car had fuel pressure I relented and took the car to a shop. I told them all I had done. The called me back and said they were 100% certain my problem was blocked Cats. They they could be replaced for $600 dollars before tax. I asked a mechanic friend in another state and he said the symptoms could lead to that. I told the shop manager ok. He later called me and told me the muffler got damaged and it was up to me as to whether I wanted to drive it with no muffler which wasn't really loud or he could order me a after market replacement. After hearing the car and being told by the shop owner that it was legal. I decided to take the car and decide on a muffler later. It actually doesn't sound abnormally loud at all. I was wondering if this is ok to drive or should I have a muffler or pipe coming back. Also is it possible that blocked cats and muffler could do this? I checked the shop on Yelp and they had all good reviews. He told me he had to core the cats so I didn't get them back. Thoughts?
  5. Wes06
    Wes06 forum member
    5,205
    Jan 21, 2012
    Dude locally had his cats clog on his 4.0 while driving. Either hollowed them out or replaced with pipes and was fine after.
    Muffler if it broke and covered the hole it's possible it prevented gasses from exiting and stalled the car
  6. RocketcarX
    RocketcarX 95% of my weight is fuel
    1,601
    Jul 19, 2011
    Burton Texas
    There is no such thing as a core on cats, however the junk man will pay up to $200 each on some of them motherfuckers.
  7. Pentalab
    Pentalab forum member
    1,869
    8
    Mar 5, 2013
    You can measure fuel rail pressure by plugging into the OBD port with either an X3 or an aeroforce gauge. Mine sits at 40 psi, but that's on a 281 ci 3V, 2010 GT.
  8. Mirage
    May 6, 2017
    Or just about any decent scan tool will allow you to read things like fuel rail pressure, fuel trim data, O2 Sensor data, etc. But this data is based on what the Fuel Rail Pressure Sensor is sending to the PCM. So if the FRPS (or Fuel Rail Temperature Sensor) is off, so is the data being sent to the PCM. Remember the fuel pressure is a function of pressure and temperature. Higher fuel rail temp, means higher pressure to keep fuel from boiling in the rail.
    Best solution is a mechanical gauge either mounted on the fuel rail or on one of the lines leading to the rail as Ford recommends.
Share This Page
