DiMora
More Is Better
Well...The S197 classifieds got the best of me, and I am taking the plunge.
I've built three engines before - two Kawasaki ZRX motorcycle engines and one push-rod V8 (Ford 335 series 400 - .030 over, full hydraulic roller-rocker setup) - but this is my first modular.
I would like advice on part selection. I'll ask some specific questions here in a minute.
Here are my goals: RELIABLE build - the car is 98% street car and show car, but I do take it down the drag strip about twice a year for some charity and social events...I rarely "compete". I would be happy in the 550-600 RWHP range on 93 pump gas. My TVS with an overdrive crank pulley and 2.75 to 3" snout pulley will make ~18 PSI if desired.
Right now, I am running:
Other noteworthy items (but not really germane to build) are a Steeda triple-pass heat exchanger, Meziere 20GPM pump, Canton icebox and full BMR / Steeda suspension upgrades.
I have already purchased (but not installed) the following short-block from Steve Poe. The block was run in an FR500S Mustang for about 3 months in a N/A configuration. I need to go through it and make sure everything is clean and inspected, but I don't anticipate any machine work or replacing any parts:
Other parts I already have in my garage awaiting the build:
Parts I need(?) to buy, but I want input from forum members so as to avoid mistakes:
Specific questions for the collective:
For my power goals, are TTY bolts good enough? I have seen too many nightmares on here with cracked aluminum blocks using ARP studs torqued to ARP spec. I could use studs and go 85 LB-FT instead of 100, or just stick with TTY. Again, I'll probably be around 18 PSI maximum.
What gaskets? I can buy a head change kit that has gaskets included (Fel-Pro?) or I can buy the Cometics I have seen recommended. Any input appreciated.
Steel or TI spring retainers, or re-use what I have? Car has 40-some thousand miles on it. Same question for the timing chain guides and tensioners. I have read that the plastic tensioners may acutally be BETTER than the 2V steel variants and that Ford changed them for a reason (less breakage) - not to be cheap.
TSS billet gears, or is the 2013 oil pump with beefy back-plate enough to solve the shattered gear concerns?
Lastly, the Comp Valve Springs are about $350. They have another set at $300 with slightly different specs.
26113-24 / 26125-24 are the part numbers. The 26125's are cost more. Link to spring data:
http://www.compcams.com/Company/CC/cam-specs/Details.aspx?csid=978&sb=2
Are there alternative brands that you guys recommend that cost less? I ask not to be cheap, but because when I did my previous builds, there were alternatives to Comp made by Lunati and Scorpion that were actually BETTER than the Comp offerings at a large cost savings.
What else am I missing from my shopping list?
Windage tray?
Thanks in advance for sharing your thoughts and knowledge.
Pics:
- Stock 4.6 GT engine
- Roush TVS R2300 with stock crank damper and a 3.47" pulley - 9PSI
- Mac Longtube headers, ProChamber, QTP cutouts, Roush extreme over-axle pipes into Roush on-road exhaust
- 52 LB injectors
- GT500 pumps
- Snow Performance Stage 3 Meth injection (not tuned for it; very light spray for safety and cooling IAT's only; no additional timing added)
- Livernois-built stock bore 4.6 block
- Kellogg custom "Livernois" forged steel 3.750" stroker crankshaft
- Manley H-Beam 5.850" Rods w/ ARP2000 bolts
- Diamond "Livernois Exclusive" forged 2618 Pro series pistons
- Diamond Rings, locks, wrist-pins
- Clevite Tri-Armor coated bearings
- 9.8:1 compression and 4.88 liters displacement (298 cubic inches)
- Comp 127350 cams: Comp Cam XFI VSR stage 2: 222/239 @ .050” duration, .490/.485, 116.5 LSA (127350 [7])
- FRPP Oil Pump #M-6600-F46 (New - with pick-up - From 2013 GT500 - high volume and has the thick steel back-plate)
- 8 rib complete conversion, with new alternator and A/C pump so I don't have to swap pulleys on those items (Off of Skwerl's wrecked car)
- Ford Racing Performance Products twin 65MM CobraJet throttle Body
- JLT 127mm Carbon Fiber BIG AIR intake
- VMP tuning TVS high-flow inlet elbow
- Kenne Bell Dual Boost-A-Pump for GT500 pumps
- McLeod 8 bolt flywheel (I currently run a 6 bolt, RXT clutch and T56 Magnum XL tranny)
- Cam phaser bolts M-6279-463V (Just ordered these a few minutes ago)
- Valve springs
- Valve Spring Retainers - Steel or Titanium, or re-use my existing ones?
- Ford TTY head bolts or ARP head studs?
- TSS billet oil pump gears?
- Gaskets (Ford / Fel Pro / Cometic?)
- Replace timing chain tensioners and guides? Plastic or 2V steel?
- Crank Damper - Innovaters West or SFI-certified OEM type?
Windage tray?
Pics:
