DivisionX Stryker 340lph Fuel Pumps NOW AVAILABLE!!
Jared@Lethal
The DivisionX Stryker fuel pump is one of the most versatile pumps available on the market today. With flow rates of 340lph@40psi (13.5V) and the ability to be run in regular gasoline as well as with E85, it makes it the perfect option for those looking to provide more fuel and safely support more power.
The Stryker pump was designed with the same dimensions and offset inlet as the Walbro GSS342 fuel pump so it acts as a direct replacement wherever the GSS342 was used. So whether it will be in a modified stock fuel assembly, DivisionX or Fore Precision Works GSS342 fuel hats the pump fits just like the Walbro GSS342. The Strkyer pump is a turbine style pump similar to the Aeromotive Stealth pump so it can be run in return style configurations as well as in pulse modulated applications/returnless style systems.
Each pump comes with a 1 year manufacturer warranty.
Pump Includes:
Fuel Pump (Offset Inlet-Inline)
(2) High Pressure Hose Clamps
Wiring Pigtail
Submersible Fuel Hose
Fuel Pump Pre-Filter
DX-340S
Flow Data Summary
Calibrated for Gasoline.
13.5V
345LPH at 40psi
335LPH at 43.5psi
310LPH at 50psi
275LPH at 60psi
260lph at 70psi
230lph at 80psi
205lph at 90psi
Compared to the Walbro GSS342
13.5V
255LPH at 40psi
225LPH at 60psi
195LPH at 80psi
165LPH at 90psi
Here's the Stryker next to a Walbro GSS342
DivisionX Stryker 340lph Fuel Pump [DX-340S] : Lethal Performance, Performance parts for Ford Mustangs
Stryker pump and the included install kit
