DIY: 2010 GT front end conversion to GT500
rkaiser
Flemington, NJ 08822
Hope the attached is helpful to those looking to do this conversion. It didn't take long to do, as long as you have all the parts:
You need an the following tools:
  • Flat Head Screwdriver
  • Phillips Head Screwdriver
  • socket wrench
  • 5mm socket (Lower shield)
  • 8mm socket (Left & Right GT500 mounts)
  • 10mm socket (GT500 Air Splitter)
Recommended Parts List:
  • Front Bumper Assembly
  • Front Air Splitter*
  • Front Grille Assembly
  • Lower Grille
  • Center Bumper Support**
  • Left Conversion Bracket*
  • Right Conversion Bracket*
  • Isolator Assembly
  • Front Grille Emblem (optional)
  • 2 Fog Lights w/ Bulbs
  • Fog Light Wiring Harness
  • GT500 OEM Hood
  • GT500 Radiator cover
*Requires Bolts / Clip_nuts
**Requires Rivets
  • 2010_GT_frontend_to_GT500.pdf
Kevinmach1
Major Member
Iowa
My question is...where do you buy all the parts???
rkaiser
Tousley Ford has the cheapest prices on factory parts I have seen. The guys at the parts desk can help you with part numbers and the ordering process. If you stick with the necessities you could probably do it cheaper then the kits for sale on ebay.
I bought the Sterling Grey hood from a guy doing the SS conversion. Ford sells them for 1400 new and I wasn't about to do that. I have a Black hood with White Stripes and a Kona Blue hood available if anyone is interested in doing the conversion.
AJ
US Muscle, AUS Hustle....
:handjob:
Ask them for a quote on a gt500 splitter, then ask us :beerdrink:
ArizonaGT
Road Course Member
Phoenix, AZ
My question is...what is the street value of that huge brick of cocaine you have at the bottom of page 2?
5.0Shocker
Resident Bomb Tech
Guam, Island life bruh
Apparently the following parts. LOL
  • Lower Grille
  • Isolator Assembly
  • GT500 OEM Hood
rkaiser
Hey it was laying there, and I needed something soft to lay the hood on. The best part is, you snort it when your done. Nothing goes to waste.
I believe it is one of the foam blocks from the hood box.
ArizonaGT
Road Course Member
Phoenix, AZ
