That all sounds very interesting but I don't known if my scan tool that came with the car will do any of that it's an old SCT and I image its functions are very limited. I've also wondered if being so old I'm able to connect it to my computer and maybe update it with a new tune. I have plans for my car that include 3.73 gears, catch can , 62mm throttle body so I'm sure those changes will need to be included in a new tune. I already have different size tire on the car and a functioning ram air hood which I think should be included in the tune.....Thoughts ?
This is why I typed to use a general OBDII scan tool\Torque or Forscan app w\ BT dongle for this instead of a tuner device........been there, done that. Not that a tuner device can't be set up to do this but we don't have all the tune PID addresses to program into the datalogging file to load into the tuner device to allow it to access all the necessary PCM PID's thru OBDII but most all general OBDII scan tools\softwares nowadays have all this & much more programmed into them by default so for a DIY'er these are the way to go for diagnostics then use your tuner device for what it was primarily meant to do.......load\swap\adjust tune files.
(warning...long posting)
Now on the advent of running a 62mm TB, these can be set up to run w\ your tune as is (also been there, done that w\ both a BBK #1763 62mm & a Ford Performance 62mm) but you will not get the most from it (throttle tip-in response\acceleration performance is the primary gain w\ top end airflow being secondary) w\o the ETC predictive throttle angle (PTA) & effective area (EA) mapping updated in tune file that matches the stock 55mm TB to match the 62mm TB's increased ID to butterfly plate OD area so the PCM can accurately calc this area change off TB TPS angle to match the MAF air load calc's created from it to then accurately calc the ETC actual engine TQ output to match the desired APP DD TQ request mapping (also been here, done that). Some tuners don't mess w\ this (as I found in my car's tune file that was dyno tuned by another tuner w\ a tune file that I got from BAMA in which they also didn't do this.....but both knew that I had a 62mm TB installed prior tuning\tune request) as it can be a PITA to set up correctly & not incur excessive + IPC TQ errors but in order to get the most out of these 62mm TB's this is imperative that it gets done, otherwise you're being short-changed on total overall performance gains expected from the 62mm TB install (throttle tip-in response\acceleration performance is what most actually feel\experience from tuning outside of peak HP\TQ) to justify it's expense\cost (better off to not buy\install if tuners won't actually do the proper tuning it needs).
Just know this......the PTA\EA of an OEM 55mm TB is 12.8% smaller than the same PTA\EA of a 62mm TB so the general engine TQ output is approx 12.8% lower than it would be during accel (ETC TB PTA\EA mapping from TPS angle air load calcs will be off--lower--compared to the actual MAF air load calcs created from the same TB TPS angle) thus creates a - IPC TQ error (tells PCM there's more MAF air load than it should be) so the PCM will fall back to the ETC TB PTA\EA mapping w\ TB TPS angle air load calc & close the TB TPS angle until the actual MAF air load corrects to the ETC TQ modeling air load calc) so in essence the 62mm TB installed will be acting\controlling like the 55mm TB it replaced in PCM TQ modeling if this ETC TB PTA\EA mapping isn't updated in the tune (why most say 62mm TB's don't gain anything......what most won't tell you is
why it won't....it ain't got nothing to do w\ the TB itself.....all in the tune....especially dependent on the tuner's abilities who is doing the tuning). - IPC TQ errors the PCM can handle (actual engine TQ output is lower than desired PCM TQ output during accel thus the PCM still has full throttle control over engine).....it's the + IPC TQ errors that are dangerous (actual engine TQ output is greater than desired PCM TQ output during accel....ETC TQ model air load calc off TB TPS angle is greater than actual MAF air load calc off same TB TPS angle so ETC will open the TB TPS angle more so the MAF air load calc will correct to the ETC TQ modeling air load calc) & if the spread is wide enough the PCM can lose control of the engine RPM's thus creating an engine runaway situation......why the IPC TQ Error Max setting in tune file is important that it stays set at the stock setting of 25,000 or lower to allow the PCM to quickly go into Limp Mode (the wrench light.....fully shuts the TB & retards spark timing\retards VCT timing & cuts injectors off if needed to cut engine TQ output to prevent engine runaway off ETC control loss.....why engine falls on its face when Limp Mode is enabled) &
it is this reason why some tuners won't touch updating the TB PTA\EA mapping in tune to match the 62mm TB's PTA\EA sizing which now makes buying 1 of these TB's a question of overall value......it will highly depend on the
tuner you choose as to whether you'll get all of its value properly & safely to justify its expense, not just the cost of the 62mm TB itself.
I'm posting all this as I don't have a dog in this hunt (meaning I don't tune for a living......only recently started to tune on my own stuff & I'm retired but I also put the time\effort in prior to learn what\how to do it) but the truth of all this needs to be known IMHO so folks can make better decisions as to whether they want to really buy 1 of these 62mm TB's or not & go thru all what it takes to fully optimize its use. Finding the
right tuner who has no issue doing this tuning properly will be your biggest challenge & if you do find 1 that can do this right, be prepared to pay for it.
Another reason why Lito's name is mentioned so often as the go to 3V tuner.........most likely he's already crossed this bridge so is second nature to him to do it (probably already has the proper PTA\EA mapping data vetted for a 62mm TB in hand by now so is already loaded in a base tune file copy when needed).
Hope this helps.
Note: 1 of these days, 1 of my tuning goals is to go thru the tuning process & properly model this TB PTA\EA mapping data for a 62mm TB to have on hand since from all I've found\seen to date no one has done this.....not even Ford.....for a 62mm TB &
posted it for public use. I used the TB PTA\EA mapping for an OEM Ford 60mm TB (pulled from a 2010 GT500 stock tune file so verified actual Ford tuned data to match the std Ford tuned ETC control settings in my tune file thus accurate so only cut & paste was necessary) to better rep my 62mm TB in my tune file's ETC TQ modeling (only 3.3% smaller instead of being 12.8% smaller so recouped 74% of the total TQ modeling gains lost thru using the OEM 55mm TB's PTA\EA data mapping w\o creating any excessive + IPC TQ errors.....actually dropped from <1,000 to <75 thru datalogging to test the new TB mapping)......you WILL feel\notice the throttle tip-in response\acceleration performance increase from the more accurate overall ETC TQ modeling to better match up to the actual calc'd MAF air load thru TB off the APP DD TQ request mapping (the mapping that the accel pedal tells the PCM's ETC TQ modeling what you the driver requests w\ your right foot). Not fully accurate\correct yet but is WAY BETTER than where it was (may also just leave well enough alone when it's all said & done as this ETC TQ tuning is where a dyno is the far & away safer method of going about doing this & I don't have access to 1.....just to make up for a 3.3% smaller TB PTA\EA difference).
Ok I'm done.....................
