06 T-RED S/C GT
After looking over my door panel, I see exactly where your coming from now. The video posted is definitely bogus, as there appears to be no backing underneath the vinyl insert that is neither removable nor can be pulled off as the person in the video claims, but rather nothing but just foam/adhesive attached to the door panel. As mentioned in a previous post, I'll just either take a wire brush or use sand paper to remove any left over adhesive/foam on the door panel before re-gluing the vinyl insert or consider going with the Coverlay replacement option instead. Meanwhile, thanks for clarifying, as I now stand corrected.It's a bogus video. You would know I'm right if you have ever attempted this job.
The "10 and newer cars up to 14 also had the same issues. Don't know if Ford fixed the issues on the S550 cars or notDo the '10 and newer cars do this too or did Ford fix it with the redesign?
Fixed!Why? Because the panels with factory inserts have sort of a gloss black plastic surface under the inserts. The panels in that video had no inserts from the factory. The backing does not just "simply remove...altogether by using a pair of pliers lol".
Nah. Not for me anyway. Even if you pull the panel you still gotta mask it.It's best by far to remove the door panel.
Also, the best fix IMO is to find a set of door panels that had no insert from the factory.
It appears that the foam was originally part of the vinyl. On my car, about 95% of the foam is remaining on the door panel. How do you remove the foam and adhesive from the door panel, in preparation for whatever is to be reinstalled?
If any of you guys are going to do it yourself, I suggest you mask off the entire door that does not need adhesive. Just run some masking tape down into. and along, the depression in the door where the fabric should be tucked into. Then tape newspaper to that tape and cover all the door, and the outside mirror, assuming you're rolling the window down. This stuff is really resilient. If yours is still attached at the bottom, don't pull it off.
Can you provide a close up picture of the new inlays?I ended up going with Coverlay also, I am really happy with them, and hopefully, I will never have to fix them again. The texture is an exact match but the color was a bit off but I would say that is because my door panels have faded somewhat over the years.
Not bad. Has an OEM look to it.
My driver side was warped a little when I installed them but it’s just me being picky as I don’t think anyone could tell where...I used the silicone it came with and mine are holding fine.Any updates from those that have installed the Coverlay inserts? I'm curious if the colder weather has caused the panel to pop loose or maybe warp. I just purchased a set and am hoping this will be a permanent fix.
