Engine build parts
05sonic4.6
Central NJ
my motor went south a few weeks back, dropped a valve and took out a piston. I was going to rebuild it but found a good deal on a short block I’ll be using so I have some parts I don’t need anymore.
I have a set of diamond -15cc pistons .020 over, one of which is brand new. The others are in good shape, only ran for about 4K. Machine shop said they were good to use. One has a very small nick in it from ptv contact but it was run as it is in my engine no problem. The pistons are currently connected to boss 5.0 connecting rods. I’d prefer keeping them together but if you want just the pistons or rods I can separate them. Just need time to do it. Connecting rods come with all new bolts.
Pistons SOLD
I have a set of arp head studs, 3v specific. In good l.
SOLD
Arp main studs and side bolts.
SOLD
Stock crank
$100
Have a set of brand new moly file fit rings for 20 over bore. Still in box.
SOLD
Set of brand new clevite main and connecting rod bearings. For aluminum blocks. Standard clearance on both.
$100
Also have a spare teksid block, just had it cleaned. One cylinder has some scuffing. Machine shop said a .020 bore will take it out though. Has arp side bolts and thread inserts for knock sensors.
$350
All prices do not include shipping. Any questions please ask away. Thanks.
