graygt07
I have an 07 gt auto with a saleen supershaker with 12# boost. My plan is to replace the engine with the aluminator. I will be getting the short block with 9.5 comp. just like the stock one. I need to know how much hp i can make and still use 93 octane. I know i should get the lower comp. but the saleen only has one smaller pulley i can put on and with an overdrive crank pulley i think i will only see 15 or 16# boost. I will be adding a cam and a larger heat exchanger. With 39# injectors and the gt500(which i have) i was thinking i will make around 525 rwhp. i dont plan on being able to higher with the saleen. Am i thinking on the right track? Anyone see a hole in my plan? anyone have a higher comp. block with a supercharger running 93 with over 500 rwhp?
