For any NE owners wanting 99 cobra tails...
DarkTrak
Small kine pimpin'
Hawaii
If you would like to swap your NE GT tails for a set of amber turns from the early model NE Cobras, I just did a set for a member of my club with an 04 Mach. For those that are adventurous enough, here is what u need and how to do it.
Supplies:
Cobra turn signal relay FoMoCo p/n 5L5Z-13350-AA
Spare tail lamp harness(2)
Spare reverse bulbs(2)
Wire strippers
Solder
Soldering iron
Shrink tube
Lighter
About 15' of 16 gauge wire
Zip ties
Dikes
Razor blade
Steps:
1. Disconnect neg terminal on batt and remove all the carpet panels in the trunk.
2. Remove tail lamp assy(both sides)
3. Remove harnesses from stock GT tail lights
4. Re-install factory harnesses into cobra housings in the corresponding locations, taking note that the GT housings have 4 bulbs openings and the cobra's have 5. So now you should have an empty hole where the amber turns are, with no socket to put there...
5. Cut the reverse lamp sockets off of the spare harnesses (2 wire, black for ground and another color i cant remember) leaving plenty room to strip the wires back and solder.
6. Install bulbs into those new sockets and put them in the amber turn holes.
7. On the Two outboard brake light sockets(3 wire) cut the wire on the opposite side of the black ground. This is the high side(brake) power, and twist them together both on the socket side and the harness side.
8. Take the socket side of the high side wires that you just twisted together and solder them to a 6' length of 16g wire. This will become your brake light feed and will be shortened later.
9. Take the harness side of the high side wires you just twisted together and solder them to the power(non black) side of the new amber turn socket.
10. Locate a black wire on the existing harness and cut back a bit of the insulation to reveal the copper wire.
11. Take the ground(black) wire of the new amber turn socket and strip and solder it to that section you just stripped back on the existing harness.
12. Cuss like a sailor because you forgot the shrink tube. At this point, either cut the wires and slide shrink tube on, or at the very least use electrical tape or liquid tape.
13. Poke a hole in the rubber grommet on each harness and feed the 6' length of 16g wire you attached through it.
14. Set the tail lights back in place just enough so u can plug the connectors back into the body harness. Do so.
15. Run the 16g jumper wires along the factory harness towards the drivers side fender well. Zip tie ass needed every 6-10".
16. Follow the harness forward and up until you find the connector that leads towards the 3rd brake light. On that connector find the SOLID GREEN WIRE. doesn't matter what side of the connector you are on, but strip back about a 1/2" section of insulation. Cut the two 16g jumper wires so the reach that section of green wire and solder them to that section. Re-insulate the solder point.
17. Now the fun begins. Crawl your happy ass under the drivers side of the dash and look up. If you are oriented laying on your back with your feet facing the trunk and head on the gas pedal, ur doing it right. Look left towards the center console. You should see a big yellow relay. Unplug it and replace it with the blue cobra one.
18. Now look at the steering column shaft. On the immediate right of it(towards the kick panel)maybe 3" to the right of the column, there is a grey wiring connecting block. On the lower right, you should see a SOLID GREEN WIRE...the same one you spliced into in the trunk....but here it is the brake light interruption into the turn signal circuit. Cut it. Yes, cut it. And insulate both ends of the cut.
19. Climb your ass out of the floor pan and re-connect the battery.
20. Test everything.
21. Your welcome.
dougie b
pics? Im not sure im understanding what you're doing exactly lol
DarkTrak
Small kine pimpin'
Hawaii
All three of you seriously cannot follow step by step directions? Where did you get lost?
rford426
Resident 5.0 H8R
Live Oak,Tx and Tulsa,OK
no your cluster fuck of words you call a step by step directions makes no sense if we don't know wtf it is we are even trying to acheive... WTF NE what? 99 cobra tails in what? a 2011? a 05-09? WTF are you talking about haha?
DarkTrak
Small kine pimpin'
Hawaii
Hey you fucking mongo, NE stands for New Edge. 99-04 bodystyle mustang? Ring a bell?
DarkTrak
Small kine pimpin'
Hawaii
Atleast im not the only one that had no fucking clue what you were saying...
Right. Whatever makes you feel like less of an asshat. Could have atleast asked before you tried to make me look like a chump.
rford426
Resident 5.0 H8R
I asked for pics...Ever heard the expression a picture is worth a thousand words? You could have posted a pic instead of your thousand words above that no one wanted/had time to read...Specially when we don't know what your even talkin about.
DarkTrak
Small kine pimpin'
Hawaii
Dont get salty because you are uninformed. It's ok to admit you are wrong. It's a good fucking write up. AND there are NE owners on this site. It's not my fault that you are too lazy to figure out what you are talking about before you bash someones hard work.
lostsoul
2014 vett or 2015 stang..
Gay Area
What was that? We need emotional content.. not anger.
Dont think.. Feeeeeeeeel
