Ford HID light harness
Barricade
Decepticon Extraordinaire
The Alamo
Ok...put in the harness and discovered there was something extra on it.
Im not sure how to mount or where Ford put it.
Any one have the HID's from Ford and can snap a pix and show me where they put it?
:High 5:
ref:
wabirch
Bill
Illinois
HID relay box for both 4.0 and 4.6.
5.4 also routes fuel pump and charge air cooler pump relays through this box.
Barricade
The Alamo
Thats it!! Thank you so much for the Pix.
I appreciate your time!!
I fired it up and only one headlight worked.
I ordered new D3S...but I gotta get the front end back on soon before she gets mad at me as the upgrade was my idea. lol
Barricade
The Alamo
Ok....thought I was missing something. I couldnt get the drivers side light to work. Changed bulbs and stillnothing. So I swapped it to the pass side harness and it fired up so Im guessing it the wiring. When I plug it in the shield snapps closed so its getting power. Maybe not enough....no idea. My next guess was the resister. I popped the cover and saw a big blank area....but I guess thats normal.
Figured I would switch them and see if the pass side now doesnt work. ha haa
The fun of troubleshooting....
I may just drop the Saleens in....I have a set of Saleen HID's. Just to get it going.
Wes06
umm, isnt that open area for a relay? shouldnt there be one?
NickD87
Toronto, Canada
what year is this on?
CDC had instructions for doing some modifications to the harness if its a pre 07
Kylar
CT, USA
You have to re-pin 2 wires in the harness and add a couple resistors. Did you do that step?
NickD87
Toronto, Canada
yep thats what I was referring too, I've had these lights on my shelf for 2 years waiting on a harness, where did you purchase it from?
MADGT
USA
^exactly my question...if OEM, do you have a part number? OK, so according to the .pdf the OEM HID Harness from 2008-newer Mustang (P.N. 8R3Z-14290-GA). I wonder what I would use for an 06?
Nevr mind...would work with an 06--just had to read some more... :)
Kylar
CT, USA
the harness is 8R3Z-14290-GA I would check the internet for the best price. I believe its around $125ish
NickD87
Toronto, Canada
yeah I wasn't looking for the part number more of did you find a deal on it, I can't find it for less than $150 which is over 200 canadian.
