Turbotungsten
- Joined
- Jan 26, 2008
- Posts
- 144
- Reaction score
- 2
Please help! I am running out of fuel with the Ford Racing Dual Pump system. My car is a single turbo car. At 7 psi, all is well, pressure is 38-40, AF steady 11.4-11.5, MAF at 3.4 volts or so, pump duty cycle is a little over 80%. At 11psi I start to loose it. pressure is around 36, AF OK, but maybe gets around 11.7, pump duty cycle about 94%, MAF around 3.7 volts. By 14psi I go lean and pressure is around 30, but pump duty cycle isn't any higher. I have the stock numbers in the pump voltage table, but with the duty cycle not at 100% I am not totally (but mostly)convinced that it is the voltage table. I am guessing that at 11psi I am around 520RWHP (ported heads, custom cams), but I would think this fuel system is good for 600RWHP. Does anyone have some numbers to plug into my voltage table as a good starting point? Any other pointers as to what is happening here? Thanks!!
