Well, I quit messing with this for a while, but I slowed down with work and have been messing with the car some more.
I wanted to eliminate a variable, so i reinstalled the gt500 pumps back in the gt500 hat, so here is my fuel system: Ford Racing dual pump system with 60lb injectors. The only think that is not original Ford racing system is that I have replaced all the corrugated line with submersible line. I have put in the GT500 pump voltage tables , and have the gains set as such.
Derivative= .000
Integral= .0550
Proportional= .060
I still have a problem, but not as bad. Here it is...
When driving around not under boost delta pressure is great.. nice and steady commanded 39
at 7 psi of boost it drops to 36, but commanded is still 39
at 12 psi of boost it drops to 33, but commander is still 39
What gives????? even at 12psi I am only at 76% duty cycle
Can I change any of my gains to help this? Is my FRP sensor bad? Is there something else in the tune that I should be looking at? It's better, but still not good.
I if had them money laying around I would go return style. I am to the point that I thought about just commanding 45psi, and adjusting the tune for the higher pressure, then I would be in the high 30's under boost. I know, that's a poor band aid, but man... what gives. Any help would be greatly appreciated.
I wish that I would have bought SCT advantage software instead of Sniper. I am not knocking Sniper, but there are just more people that could help with looking at my tune with SCT.
