After alot of back and forth i have decided to part out the car for a number of reason, mainly lack of time to deal with or enjoy it and the fact its become more of a race car than i wanted. Will have A LOT more stuff for sale very shortly.
long Block
Teksid block 0.20 over
Kellog 3.75 stroker crank
Probe 4340 I-Beam rods
Custom CP pistons (9.3 compression)
ARP hardware throughout including head studs
stock heads
comp 12750 cams, upgraded springs, lockouts
electric water pump
Motor has ~1,500 on it currently and has supported 700rwhp through stock heads and cams. Dyno'd 315/350 n/a before the blower on a break in tune.
$4500 plus shipping or picked up
Procharger F1A
Polished Procharger F1A 12 Rib kit complete. Comes with ATI Dampener, complete 12 rib kit. The 4.3" makes 27psi@7000rpm on my particular combo. I'll also include an HPX mass air meter along with the blower.
$4200 plus shipping or picked up
fore tripple pump fuel system- returnless
Fore Triple pump hat anodized black
3 GT Pumps
MDM Megadriver
#8 line
3-1 y block
Fore Billet Fuel rails anodized black
FRPP 80lb/hr injectors
This system has supported 700rwhp on E85 with some room to go on the fuel pumps. On race gas this same system will support well over 1000rwhp.
$1100 plus shipping
gt500 front clip
gt500 bumper, uppper/ lower grilles, headlights, mounting brackets, bumper foam. bumper is factory black and does have scratches on the front and one of the turn signal brackets is broken, will still hold it but wanted to let buyer know.
$950 plus shipping or picked up
th400
ATI Grinner Transbrake TH400 Part # 401361, race clutched and steels,blueprinted high flow front pump, ATI reverse manual valvebody,ATI HD sparg assembly,ATI HD support,OEM trans. pan. cost$2034.56
BellHousing-SFI 30.1 for modular 4.6-5.4 cost $642.88
Adaptor ring for Ford c-4 bell to Th400 cost$292.74
Flexplate- SFI Modular 4.6-5.4 w/ GM Trans.
ATI 10" fuel and blown converter part # 408420 cost $1188.75
Features 22 element sprag and double caage construction to simultaneously control each sprag.
Evolution billet crossmember with billet adapter block cost $475
Custom made chrome moly drive shaft with moser 1350 pinion yoke, this will support 1200 hp. cost $700
B&M Pro stick shifter with magnum grip part # 81040 with reverse pattern
cost $267.90
deep aftermarket trans pan w/ temp sensor bung
dual delco coolers with fans and an lines/ fittings
flex dipstick
Add all this up and you get almost 6400. I would like to sell this as a kit, so there is no guess work as to what you need, its all there.
$4000 plus shipping or picked up
mods- i have a few pictures but am going to get better ones tonight to hopefully show everything better, kinda hard with it all still in the car
matt
long Block
stock heads
electric water pump
Procharger F1A
3 GT Pumps
MDM Megadriver
#8 line
3-1 y block
$1100 plus shipping
gt500 front clip
th400
cost $267.90
flex dipstick
matt
