95PreludeSi
- Joined
- Aug 7, 2010
- Posts
- 11
- Reaction score
- 0
I know there are a lot of FR500 threads around here, and quite a few folks have put them on 05-09's without issues. Just wanted to report in that if you have standard brakes on a 2011GT you will need to add spacers in the front to make sure they clear the calipers. I ordered 4 18x10s from CC, and they came as expected. However, when test fitting them I noticed they rubbed on the caliper when rotating the wheel. So you need a little clearance. Right now 5mm spacers did the trick, although I have some 3mm spacers and will try those later. Other than that they are doing fine.
