FS: S197 Drift Car
tr_racing
Quebec
So now it's real, no more budget to compet anymore & need to take care more of my family so time to past to another things. I'm selling my Ford Mustang Drift car. The car is still new, we finish it last october & I only burn 5 sets of tires with it. You can see the build here: http://s197forum.com/forum/showthread.php?t=77515
Here the list:
Motor 2011 Ford 5.0 Coyote
MMR 5.0 head cooling mod
Ford Racing control pack ecu
Stainlesswork 1 7/8” long tube header
Custom exhaust
Custom air intake
SCT Tuned 395whp/360wtq
Custom fuel system w/ Aeromotive A1000 pump, regulator, filter (-8 feed, -6 return) + Metco fuel rail + cut in half oem fuel tank & swirl pot
Racepak IQ3 display dash + Racepak OBDII harness
Custom fiberglass dash
Flexalite 38” aluminum rear mount radiator & flexalite dual fan 6000cfm & custom -20 braided SS lines
Ford Racing remote mount oil filter
Derale hyper-cool oil cooler
Custom chassis harness with Moroso toggle switch/board
Kill switch
OMP fire surpression
Transmission TR3650 w/ 26 splines input shaft
ACT twin plate clutch
Steeda Tri-AX shifter
Ford Racing 4.30 rear end
Eaton Detroit locker LSD
OEM front brembo brake
Custom twin caliper setup for e-brake w/ Wilwood 4 pistons caliper
ASD hydro e-brake
Standard Suspension drift spec coilover w/ custom spring rate (8/6)
Ground Control Race camber/caster plate
Custom Texas made front steering knuckle (+60 degree)
QA1 outer tie rod
BMR rear suspension parts (LCA, LCA relocation bracket, panhard bar, panhard bar relocation bracket, upper panhard bar rod support, UCA)
2008 BIW chassis
3121 pounds with oem complet door (don't have instal my fiber door skin)
Custom 2011 body conversion (fiberglass roof, door skin, rear quarter, trunk, hood) (also come with all the mold to make spare fiberglass parts)
OEM 2011 front fender & bumpers covers
Custom roll cage with gusset (FD, XDC, DMCC & all Pro-AM spec)
Custom front & rear tubular bumper
Chassis powder coat in white
Sparco racing seat (Pro2000 driver, Sprint pass.)
Sparco side mount & seat base
Scrotch racing harness
Tilton 600 series overhung mount pedal set
Tilton 75 series master cylinder
Custom steering shaft & steering quick release & suede Personal steering wheel
4x 18.8.5 +10 Forgestar CF5 wheel w/ 245/40R18 Porenza RE11
6x 18x9.5 +30 Forgestar CF5 wheel
6x 18x9.5 +35 FAST wheel
1.5” front wheel spacer
ARP rear wheel stud
4x Kumho V70A tire (2x 265/35R18 & 2x 285/35R18)
Asking price: $45,000, I'm open to trade for speedbike+cash or street car+cash. The car come with all the mold to make some spare fiberglass parts, all my wheels & drift tires!
video from the test day: http://www.youtube.com/watch?v=8VGLmar9Ukc
Thanks, Kevin
tr_racing
Quebec
Here some pics:
tr_racing
Quebec
It's 3121 pound with the oem 2011 complet door (I still don't install my fiberglass skin & still have the full inner door & door reinforced). Full of gaz & fluids!
The weight distribution is 54.4/45.6
Here is a pics of the door:
Kevin
