FS trunk tank with rule 2000 pump
PNR Welding
Hammonton, NJ
I just signed up for vendor. I have some things I'm working on for our cars.
Water tanks, fuel cell that will fit stock pump hat (big weight savings) and can be used in return style with stock hat twin pumps.
For this thread is:
For sale is a trunk mount ice tank with pump installed. Rule 2000 pump with feed, return and drain.
6" lid for water and ice.
Comes with 3 brackets for install in trunk.
3 bungs installed.
Feed and return are 1" npt, drain is 3/4"npt.
Holds 7gallons
400.00 shipped
PNR Welding
Hammonton, NJ
All these tanks can be powdercorated coated also.
I can do this tank with a rule 1100 pump for 340.00
Or 300 with no pump.
Also have a 12x12x10 tank with rule 2000 pump for 325.00 shipped
350.00 shipped for polished
Powdercoated also available
1" bungs for feed and return and 3/4" npt for drain.
05armygt
Just Works Here
Texas
These look amazing! Can you make one that will fit into the battery spot of an 05? Most likely powdercoated as well
rdsx18
Looks great! I'd love to have one that can keep the oem stuff where it is, I do not feel like wiring my battery in the trunk tight now. Any chance you will be making a bigger intercooler tank like that?
Sent from my Icon using Tapatalk
PNR Welding
Hammonton, NJ
Bigger as in more gallons for trunk?
I have a 11 gallon in my car. I make them bigger to fit a rule 3700 pump in it.
I have a vendor page setup now. I'll post pictures here and over there of it.
rdsx18
Not in the trunk, but damn that is a big tank! Lol I have seen them behind the front bumper, anything like that in the works?
PNR Welding
Hammonton, NJ
Oh a heat exchanger for turbo/centrifical.
I can make it if someone wants it, as if when I'm not sure.
We are finishing designing a fuel cell for the stock pump setup to drop in. Save weight or run both pump setups together.
You still need the holding tank for the water to sit in.
Dustin CPR makes a killer one like your looking for.
PNR Welding
Hammonton, NJ
This is one that I'm finishing up now that will allow you to use a rule 2000 pump and mounts in battery location. R&D version
