BruceH
BBB Big Bore Boss 322
Josh, have you had any issues with your current 11:1 motor, boost, and e85?
No, I have not. The only issue that I ever had with the 11:1 engine were the two cam followers that broke. My car never has been and never will be a DD. I have taken it to a few cruise nights and have had no issues what so ever with just putting around town at 15-20mph.
I see the equation the other way around from how you describe it. If a point of compression is worth roughly 10-20rwhp and a widely accepted rating for superchargers is 20rwhp per psi. Then you could drop your compression 1 point and loose say 20rwhp. But then add 3lbs of boost to get the same overall effective compression you had before, but now you picked up 60rwhp for a net gain of 40rwhp (you have more air and fuel in the motor at the same af ratio) and your end result is the same final effective compression ratio.
I run pump gas more often still as its more practical for a car I like to drive to and from work a lot. Actually haven't put e85 back in the car since my last track outing.
Once my new setup is up and running and off the dyno and warm weather is around I will run e85 more often.
The fuel is going to be the same no matter the compression for x amount of HP though right?
I am still not arguing directly in either direction. My engine at 12.7 should require less lbs/min to make x HP than say a 10.5:1 with the 11cc pistons right? Th engine itself is compressing more air by itself so it isn't Dependant on the turbo to force or flow the air for it. Thus making this turbo more capable? Is this completely off base? This is the idea I was asking about when I made the Compression vs Boost" thread a year or so ago.
I think you need to find out the efficiency range of the turbo you just bought. No point in running high compression just to run that turbo at 10psi. I think either combo will get you to what you want, since you just bought the turbo, and that's probably not going to change....start there and work your way back.
How much boost are you wanting to make? What feels comfortable to you? What's the HP goal? Are you dead set on the boss block? What compression will it take to get you there?
