Your picture makes me wonder why my copper head gaskets don't have sealant around the head studs?Lol... what I was thinking when I installed these bad boys..
Mocked up. Taking to get manifold polished tomorrow took a lot of discipline lol. Wanted to just drop it in. I still need parts from department of boost so can't run it yet anyway. Hopefully they send them soon
Even tho this is just the "little" 3.4L..thing is massive
I would for a black heat dissipating coating with your color choices you have on the other parts. JMO
Fuck I want one now
Thought about that too. This is also kinda "show" piece or I would have done that in ceramic
The manifold in ceramic? That would keep heat in.
Crown I may have an in with the Midwest street guys... the guy that built my motor is there go to guy. He built the murder nova engine and works a looooot with chief on their stuff.
Dohhh! Meant the pan.. Taking that to get ceramic coated. If I did not want to showcase the manifold I would have had it anodized black. Seen one that was done and looked wicked
Trying to chew gum and walk right now. Brain is too small to do both
I did a test on pan coatings/shielding last week. The ceramic was effectively useless. So were the "film" type heat shields. They do something, like 0-5deg something. But not much.
DEI #050501 on the other hand is AMAZING! The pan interior ran 60-65deg cooler than everything else. It almost prevented all heat transfer. Use this.
http://www.summitracing.com/parts/dei-050501
And don't forget to grind you knock sensor pads down for more clearance.
Thanks. I used that in the past. Did not expect it to be that much better
Already ground down the ks pads and trimmed for the alt. I did have to clearance the area in front for the manifold. The area between the heads.
The Fox Lake heads are hogged out ridiculous like the livernoise stage 3 so will have to be extremely careful when setting the manifold. I specifically told them NOT to do that but they did anyway.. not much room left for the intake to head gaskets. I may ditch the green gaskets and just seal the intake with rtv. Nice thing is I get a real clear picture using the phenolic spacer
K. Will get you pics. I am going to get some short fasteners so I can to a quick test on the gaskets. It will be fine but I am going to scribe the heads where the gaskets line up best. That should help me place the manifold on install when I can't see the gaskets.
I will also test the limits on the plates adjustment to see if I "could" even get the gaskets out of limits. Doubt that also
