gt500 complete fuel system from s&h performance
Bobby
turbo gt about to go fast
Here is the gt500 complete fuel system. Comes complete from wiring harnes to injectors.
gt500 level 3 returnless $1725.00
1200 rwhp capable returnless fuel system with simple and effective hose routing. The feed line input to the front of the driver side rail and crosses over behind the motor.
INCLUDES
  • S197-S Fuel Hat
  • GT500 Billet Fuel Rails
  • F10 Inline Fuel Filter
  • All fittings, hose, and hardware necessary to complete typical fuel line plumbing
    -15 feet of fuel line and 6 matching hose ends
    -Qty 3, low profile 90 degree -8 AN to -8 o-ring fittings
    -Qty 2, -8 AN to -10 o-ring fittings
    -Qty 1, low profile 180 degree -8 o-ring/female to -8 o-ring/male fitting
    -Qty 2, -8 o-ring plugs
    -Qty 1, -8 AN to -8 o-ring fittings
    -Qty 5, -8 hose straps with stainless mounting screws
    -Qty 2, 1/8 NPT plugs
  • 1000cc injectors
  • fuel pump wiring harness
gt500- complete Return System $2300.00
1200 rwhp capable return fuel system made with top shelf components. The feed line enters our F4i regulator, then distribution lines feed to the rear of both fuel rails.
INCLUDES
  • gt500 Fuel Hat with Viton upgrade
  • driver and passenger side fuel rails (black or clear)
  • Dual DCSS405 Fuel Pumps
  • F4i Fuel Pressure Regulator
  • s197fc2 controller Billet Fuel Rails
  • F10 Inline Fuel Filter with Viton upgrade
  • All fittings, hose and hardware necessary to complete typical fuel line plumbing
    -Aeroquip -8 Kevlar/Nomex Fuel Line (two 15' sections for feed, distribution, and return lines)
    -Qty 4, low profile 90 degree -8 AN to -8 o-ring fittings
    -Qty 5, -8 AN to -10 o-ring fittings
    -Qty 3, -8 o-ring plug
    -Qty 10, -8 hose straps with stainless mounting screws
    -Qty 9, -8 hose ends, straight
    -Qty 1, -8 hose end, 90 degrees
    -Qty 1, 1/8 NPT plug
    -0-100 psi Fuel Pressure Gauge
    -6mL Loctite 567
  • 1000cc injectors
  • fc2 controller
Upgrades
fuel pressure gauge $25.00
boost/vaccume manifold kit $75.00
465 pumps $100.00 (return style only)
fc3 controller $40.00
-10an feed upgrade $90.00
stainless steel reusable filter $30.00
billet mounting bracket for fuel filter $40.00
Greg Hazlett
Stepping on the Pink Bus
Chesapeake, VA
Jeremy will be unavailable until Dec so contact Bobby or I for your needs.
