Some may remember I had a thread concerning 13/14 gt500 pump wiring, and another regarding the viability of stacking heat exchangers. After getting all the parts together, this afternoon I tackled tearing down the heat exchanger/pump system on my '13 Roush TVS supercharged 5.0 f150. It took probably 3 hours to drain it, tear everything out and start over, including adding a new heat exchanger and the gt500 pump.
The old system consisted of the standard bosch pump, the standard lower heat exchanger and the additional upper heat exchanger that Roush sells as an upgrade to the package. Also behind the upper heat exchanger I had previously installed a permacool slim 14" fan. All of this netted iat2f's that hovered/averaged perhaps 40 to 45 degrees above ambient, once the truck has been running for a while and everything is good and heat soaked.
The new system consists of the two original heat exchangers, plus one I picked up from ebay that's 22x6.75x2.75. I mounted this in front of the existing heat exchanger(sorry for the picture being sideways) in a position that would be most beneficial as it relates to the fan behind the existing upper heat exchanger. In addition the gt500 pump now replaces the bosch pump.
The result of all this? Not much. I may have reduced iat2f's by perhaps 5* on average, but that's about it. I didn't spend that much money, but I didn't net the results I was hoping for, either.
Someone in one of the other threads mentioned that he had some foaming after installing the gt500 pump. I can tell you, there is indeed some aeration of the coolant taking place with the gt500 pump. The movement of the coolant in the degas bottle is now quite violent, compared to previously with the bosch pump. Without the pump running, the coolant looks perfectly normal. With the pump running, it becomes milky looking. I removed a few drops of coolant and placed in the top of the bottle, and it was very obvious the coolant is being thrashed by the pump. The coolant sort of looks like soda pop when it fizzes down after pouring it in a glass.
I think this may contribute to not seeing the reduced iat2f's I was hoping for.
top left (sorry for the pic being sideways) is the new heat exchanger stacked in front of the original upper heat exchanger, top right is the existing lower and upper heat exchangers that remained from the old system, bottom left is the new gt500 pump, (which requires the axis to be mounted horizontally, as compared to the bosch which was vertical). bottom right is just a bonus picture whore opportunity.
So I spent probably close to $400 doing all this, and didn't net much. I think perhaps any considerable improvement would require replacing the intake manifold/intercooler arrangement with something similar to a DOB kit. Unfortunately, I'm not willing to spend that kind of coin to find out.
BTW I'm running a mixture of about 60% distilled water and 40% anti freeze.
Oh, I'm open to suggestions/criticisms, or any ideas to improve iat2f's, short of replacing the intercooler/manifold, thanks.
