05roush0090
I have accumulated a lot of the necessary gt500 components for a DOB/gt500 sc set up. Originally I was going to put together all the components and sell packages but I don't have the time to do so but I did start on the first package and this is what I have accumulated. Only a few more things to get from here so this is a big head start for someone interested. If you we're local I could help you find the rest of what you need and help or install it for you.
Components included:
-m122 blower (stock pulley, homemade egr delete installed and tab under snout removed)
-blower elbow (bolts included)
-gt500 tb (minus electronics)
-stock 07-09 air intake (I planned on ditching the box and using a frpp cai)
-gt500 fuel rails
-gt500 heat exchanger (07-09)
-gt500 degas bottle
-stock gt tensioner (needed for frankentensioner)
-stock gt alternator (this was my alternator with the ears removed)
-stock gt alt harness (to be used to extend your current alt harness)
-one m8-60mm bolt (to replace a bolt in the timing cover the stock bolt has a bigger head on it so you get more clearance with this bolt)
$1100 plus 3% PayPal fees and it is all yours. I will cover shipping. I know some one is going to ask what else is need so I will tell ya off the top of my head so it is by no means all inclusive.
Needed:
-injectors (39-52lbers)
-fuel flow (one of Jeremy's pump upgrades or a BAP will suffice)
-IAT sensor
-2 3/4npt x 3/4 hose barb at 45degree angle (got mine from jegs)
-1/4npt x 1/4 hose barb fitting
-1/2npt x 3/4 hose barb fitting
-intercooler pump (I used a Bosch from eBay and a mounting bracket from silicone intakes.com along with a magnuson wiring kit I also got on eBay, depending on pump location you may have to extend the wires but it is simple if you look up the magnuson intercooled instructions for our cars. It wires it up so that the pump comes on when you turn the key on.)
-3/4 heater hose (need quite a bit as this is used for you intercooler lines.
-vacuum caps (various sizes 3/8 mainly)
-3/8 fuel injection hose (used for fuel lines and I also used it for my PCV lines)
I am probably forgetting something I'm sure but like I said this is not all inclusive list.
-gt500 fuel rails
-gt500 degas bottle
Needed:
-IAT sensor
