head unit has no power
ROUSH06GA
MADISON, GA
I have a kenwood Dnx 7100 for about 6yrs now. The head unit will not turn on. I checked the fuses and they all look good. Any help would be appreciated. Thanks
01yellerCobra
San Diego, CA
You need to make sure there's power at the plug going into the head unit. If there is then your head unit is dead. If there isn't time to start back tracking.
kylecm85
Lexington, KY
There should be a little reset button on the front of the unit. It's hard to see. You can use a pin to hit it and see if that works. If unlit. Check your fuses. Then if those are good. Pull the radio and check for power and ground at the plug. Also may be a fuse in the head unit.
ROUSH06GA
MADISON, GA
Unplug the battery and let the car reset?
Will try that tomorrow, when I get home
I will look for it and will double check the fuses again
Mine did the same thing and I checked the #6 accessory fuse and bam it was blown.
is that fuse in the kick Panel or under the hood, so i can go straight to it tomorrow.
