ROUSH06GA
I have a kenwood Dnx 7100 for about 6yrs now. The head unit will not turn on. I checked the fuses and they all look good. Any help would be appreciated. Thanks
Unplug the battery and let the car reset?
I will look for it and will double check the fuses againThere should be a little reset button on the front of the unit. It's hard to see. You can use a pin to hit it and see if that works. If unlit. Check your fuses. Then if those are good. Pull the radio and check for power and ground at the plug. Also may be a fuse in the head unit.
Mine did the same thing and I checked the #6 accessory fuse and bam it was blown.
