This is a general question, and I'm looking for perhaps a variety of data.
Generally speaking, what should one expect regarding heat exchangers and the temperature of the coolant circulating within the system? I know there are many variables...boost, ambient temps, intake air temps, engine coolant temps, cylinder head temps, and so on.
I am trying to determine the level of efficiency of my current heat exchanger set up, and whether or not upgrading to an afco dual pass/fan unit would net worthwhile results (as it relates to iat2f's).
I bought a trail tech tto in line 19mm coolant temp monitor to determine actual system temperatures (aside from measuring temps at the expansion tank). I was surprised to find basically no difference in temps between the expansion tank (post intercooler) and the pre intercooler (post heat exchanger) temps.
Any and all information is appreciated, thanks.
By the way, the intercooler's efficiency is a thread for another day. It's to expensive to swap out. Thanks in advance!
