Department Of Boost
Alpha Geek
- Joined
- May 26, 2010
- Posts
- 8,809
- Reaction score
- 28
Oh have I!!!!^^^ Good stuff. Has DOB experimented with triple pass units or double pass with regard to finding the optimal recirc pump with respect to the typical 2300 TVS and kitted IC on Coyotes as well as 4.6 3v's?
I've done more water pump testing than anyone else on the planet. No shit, that's a fact. Feast your eyes on this (this isn't even close to all the data):
As far as the whole single/double/triple pass thing goes it's not a one size fits all answer. More passes is not a guarantee of better efficiency. For example, if the HE core is not big enough and you make it a triple pass you will introduce a restriction into the system and slow down water flow. The slower water flow hurts more than any perceived advantage from having more passes. Some of the triple pass units out there are too small.
I work with Griffin (they make my stuff for me) on passes, etc. They are not fans of more passes. And they have done a lot more testing than most.
For Griffin and me it comes down to packaging. If you need the inlet/outlet on the same side you go dual pass. And frankly if the inlet/outlet are to be on opposite sides they and I would go with a single pass. But the market demands more passes so the one I have coming out shortly will be a triple. Granted, it's big enough so it won't be a flow restriction.
That's 100% myth. There is a point where you don't NEED to move the water any faster. But you can't move the water too fast. I've run the system on my blue car from 4.25gpm to 26gpm and every time water speed went up IAT's went down. Somewhere out there is the point of diminishing returns. I haven't found it yet and there aren't any pumps to pump faster anyway.At what point (if any) does flow increase become a problem with the HE not pulling enough heat from the coolant (due to lower time in the HE as flow increases) before it reenters the IC?
I have a HUGE article that covers why water speed doesn't hurt. It's very long and very complicated. It took me a long time to get my head around it enough to be able to articulate it to others. Hopefully I can chip some time out and get her done soon.
Yes, you're correct. I haven't found that point though. And I've run water a WHOLE LOT faster than anyone else.I would think there would be a flow velocity that once exceeded becomes less efficient just as lack of flow would be with regard to the IC side on the bottom end correct? Or at least a point at which increased flow beyond a certain point no longer improves the loop process. the velocity to heat removal would chart out parabolic or rise and plateau at best correct?
