DKS
Wax on, Wax off.
I just took my car in for gears and my bearing were bad. I was told that my pinion angle was way too positive due to my setup.
I have FRPP K springs (1.5" drop)
I also have. . . .
UMI Panhard Bar
UMI Lower Control arms (non adjustable)
UMI bolt in relocation brackets
Some people are telling me that the relocation brackets are causing my pinion angle to be off and I need an adjustable Upper control arm to fix it.
Others are saying that with my setup, my pinion angle should be fine and the LCA/Brackets do nothing to change my pinion angle. If that's the case, then I don't know why it's off.
I have my LCA in the lowest setting in the relocation brackets.
Should I move them up?
Should I just get the UCA and that should take care of it?
Is it normal to have a pinion angle problem with my springs and your products?
Can I get away with just your adjustable UCA to fix this or do I also need the mount?
Is the one you sell on car adjustable?
And what's the best deal you can ship me one to 24363 for since I'm a loyal UMI user, lol (PM me this if you wish)
I also have. . . .
UMI Panhard Bar
