Slow 3v still cant hook
TheFourSixThatCould
Socal
I have a 08 gt, 5 speed, 320whp, and can’t hook for the life of me. I’m sure it’s 60% driver mod as I’m new to this but it’s got a built motor and I told myself I won’t boost it untill I can hook. The setup is
Viking double adjustable shock
Bmr springs
Gt500 FRP lower control arms
18’ 275/45/18 Firestone indy 500.
I can get a decent burnout but launching at 2500rpm is all spin. Any advice or videos to watch would be greatly appreacted as I cant get a sub 2’ 60 foot which is sad. I would think I don’t need a drag pack for a 300hp car also.
How much air pressure do u have in the rear tires ? Perhaps launching at a slightly lower rpm might help.
AHaze
Edmonton, AB
I'm on the same tires. I spent hours hot lapping an 1/8th mile track last summer in pursuit of a decent 60'. All manner of clutch engagement technique / launch rpm combinations traction control on and off, pressures down to 15 psi. Nothing worked.
All three rear control arms are aftermarket and I have relocation brackets on the lowers. Wanted to go back with the front sway bar removed but it never happened. Doubtful it would have been enough to get me a 1.9x anyway.
I have a 08 gt, 5 speed, 320whp, and can’t hook for the life of me. I’m sure it’s 60% driver mod as I’m new to this but it’s got a built motor and I told myself I won’t boost it until I can hook. The setup is
Bmr springs
I can get a decent burnout but launching at 2500rpm is all spin. Any advice or videos to watch would be greatly appreciated as I cant get a sub 2’ 60 foot which is sad. I would think I don’t need a drag pack for a 300hp car also.
Try launching at 2000 rpm and, as others have suggested, get a softer compound tire.
Your rear lower control arms need to be parallel to the ground and since your car is lowered, you'll probably need relocation brackets to adjust their position. Lowering the car will also require an adjustable Panhard bar to recenter the rear axle, and an adjustable UCA to reset the pinion angle.
You didn't mention axle gears so I assume you still have the stock 3.31. What were you planning for boost in the future?
Midlife Crises
Fairbanks, Alaska
With stickier tires and the relocation brackets in place you can begin adjusting the dampers. Start with the front shocks soft so the front can rise and the rear shocks stiff so the rear does not move much. Get someone to Video the car launch so you can review how the car reacts. Only make one change at a time and see what it does. When the suspension starts to work you still have to deal with the fact that every piece of blacktop is different.
MrBhp
Start with full stiff on rear dampers. Full soft on front. Lower tire pressure only works on tires that are designed for it. If you run low pressure on a street tire you are taking away contact area. The idea of lower tire pressure is to get more contact area by getting the sidewall to flex to the point of creating a large flat spot at the contact area. That will not work on a radial street tire. I believe your tire is a cornering tire. Which means stiff sidewall. Don't expect a lot out of it from a dig. Before you drop money on anything else, get some sticky tires.
BottleRocket
BMR makes a drag package that should get you started but stickier tires are probably going to be your next step. You realize that there is a connection between tire compound and tread life, you can't have both. What lot of guys do is pick up an extra pair of wheels and mount them when they are headed to the track. Until then just try starting out like you are pulling out from a stop light. Then start counting, one thousand one, one thousand two, etc., find a place where you can floor it. If read articles when pro drag racers will do this when testing street cars for magazine articles.
FL/MA
Bmr springs
As mentioned already, sticky tires are the shortest path to a good launch. I have a 2012 GT (probably 350 RWHP?) with an MT-82 manual transmission and a 3.73 rear axle. With 275/60R15 Mickey Thompson ET Street S/S tires and on a marginally prepped surface, I can launch at 4300 RPM. I have managed a couple of 1.75 60 fts and most are 1.8x. I haven't tried using these tires on the street, although they are DOT approved. In addition to the tires, I have FP rear LCAs and a Steeda tune, but that's all. On the stock 235/50R18s, I could never hook on street, and only launch at around 3000 RPM at the track. I did manage a few 1.9x 60 fts, but most were 2.0x. The tires made all the difference.
TheFourSixThatCould
Socal
I have a BMR UPC waiting to install but figure now nothing is gonna help me more then a tire. And a DOB manifold kit with a m122 then move up to a trinity blower way down the line.
TheFourSixThatCould
Socal
Yea definitely a better tire for track only and daily the Indy’s.
Midlife Crises
Fairbanks, Alaska
Your car is lowered with the BMR springs. This changes the geometry and will not help you get ahold of the ground. Even good tires are going to spin. Using relocation brackets to increase anti squat while controlling the weight transfer with the damper adjustments are basic steps to getting an S197 out of the hole. If you already have an adjustable upper arm you should install it and correct the pinion angle.
This is what a 1.5 sec. 60 looks like. It is not perfect .
TheFourSixThatCould
Socal
What tire you on man? Any PA? Stick or auto? Appraise the advice your car looks mean
Midlife Crises
Fairbanks, Alaska
The tire in the picture is a 28X10.5-15 Mickey Thompson ET Drag slick on a 10” wheel with tube and 10 psi air pressure, warm. The high points of the car are listed under the pic but basically is a T56 magnum 6 speed stick with a 266 first gear and 4.30 gears in the rear. It took experimenting to get it to do that and I think it can do a little better
