timfoster405
Quick question... my 2007 only has 17k miles. I have only run it at the track on DR's about 8 times...my best run was today on a 12 psi pulley.
11.05 sec at 122 mph w/ a 1.60 60 ft.
While doing the burn-out, I had only one tire spinning. I went ahead anyway and ran my best run to date.
My rear is completely stock w/ 3.31 gears.
Does this mean my posi unit is trashed? worn out?
On the street, I can get both wheel spinning not problem and when I left the line today, I did not spin at all... very clean launch from about 2000 rpms w/ my auto.
Bottom-line, what does it take to wear out a factory posi unit? Is my hp level too much for the factory posi unit?
Lastly... is the carbon disc re-build kit any good? or should I just get an Eaton unit?
thanks,
thanks,
