TonyN
Ford Junkie
ok so i tore into it today to see if i could find and air leak. nfg. but im going to describe the problem in detail and see if anyone can figure something out.
car starts a little rough but idles fine after first COLD startup. the car will run goos until it is warmed up and then it runs like poo. im getting codes 0500 and 0345 but not at the same time, only one or the other. when it does start running crappy, it idles around 5-600 and sounds like i have a monster cam. it sounds like the timing is fucked. also sometimes if i rev it to 5500, it comes down and idles normal. while i had the intake off today it was upside down and i got a good bit of oil out of the throttle body. i may have a pic of that later. i checked and rechecked all the cmdp gaskets. i made sure the surfaces were clean. when i run my old tune, it runs fine but i get a wrench light for the cmdps. im basically going batshit crazy with this thing. what could it be?
Sure sounds like it's a tune issue since it runs fine with the old tune and crappy with the new one (fuel issues?). Codes seem sporadic...?
P0345 - Camshaft Position Sensor A Circuit (Bank 2)
P0500 - Vehicle Speed Sensor (VSS) A
