I have a '12 brembo, mostly DD. I'm in Chicago and will be driving in the winter on 28" winter tires.
I bought some parts to make the car handle a bit better.
Please tell me if I'm on the right track.
I'm going to install P srings front and 55D rear w/Yellows(for winter), I'm assuming with this low of a rear drop I'm not going to have to correct the suspension geometry.
I also have a set of adjustable Strano sways(front and rear). What settings should i start with for a DD winter set-up?
I'm going to put in a panhard bar in now, since I'll need it later when I go lower.
In the spring I want to run a 18x9.5 rim w/265 40 18 re-11 on the front and a 18x11 w/305 35 18 555R rear. At that point I'll put in the P srings in the rear as well for the additional drop. Would I need to correct the suspension geometry at that point? What is the best way, if I do? How should I adjust the sway bars for the much larger much stickier tires? I also have a Dynotech aluminum Ds installed, if that make a differance in the importance of having a correct pinion angle.
Thanks.
Thanks.
