Their Watts link failed pretty spectacularly for several people.
AFAIK, only 3 of em failed..and all due to one bad weld. If the center prop weld is bad, it will let go fairly quickly, like within months. The only other issue that I know about about was of the 5 x bolts that hold the spider to the differential, 4 of em are torqued to 60 ft lbs. The 5th one (shorter), gets 40 ft lbs. The original spec was 60 ft lbs on all 5 of em. Dimora broke the short one, and reported it to Whiteline, who revised the TQ spec asap, on the 5th bolt.
I have beat on mine pretty good for years now, and also inspected the weld several times, it's good. It's a big improvement over the previous on car adjustable BMR PHB...which was a big improvement over the mickey mouse non adjustable oem phb.
