High fuel pressure and stalling
Cole
Happy New Years guys. I’m reaching out to you all hoping you can help me.
I’m having issues with my 08 V6. It started with a code for high pressure at fuel rail, which I proceeded to ignore until my car stopped running about a month later.
Now the issue presents its self as follows:
Car will start and run at idle for about 2 minutes, then stall. The fuel pressure (at fuel rail) will range from 37-40 psi while idling. The fuel pressure will drop to 34psi for a split second, then peak to 72 psi, then the engine will stall.
I’ve replaced the fuel rail pressure sensor, and the fuel pump, and the problem persists.
Anyone have a clue if what’s going on here?
Did you replace just the fuel pump or the complete assembly with fuel pressure regulator and gauge sending unit?
Sounds like a faulty fuel pressure regulator.
