Captain_Stangin'
Hi guys, I come to you as a former drag racer, now hooked on turns after my first "race driver training" course at River's Edge in Mission, BC (http://www.sccbc.net).
My car is basically stock, I have just CAI and canned diablosport tune for power. For suspension, I have rod-end adjustable UCA with mount, fixed rod/poly LCAs, rod/poly PHB, PHB brace, and K-member brace with torque limiters. I have stock springs, dampers, and swaybars. Tires are factory 235/55/17 Pirelli all-seasons. Please offer recommendations on the following:
1. Brakes. Before heading to the track, I installed a set of 4 braided steel brake lines, EBC Red front pads, front powerslot rotors, and flushed the system with about 1.25 litres of Wilwood EXP 600. Rear brakes are stock rotors and pads. With this setup, brake fade is very apparent near the end of a 20 minute session. I got home today to check my pads, and the fronts are cooked, they feel "crunchy" when I press my fingers on the sides. I can actually see white flecks and small pieces coming off when I push on the pads. I will not be driving my car until I fix this. That said, do you guys think a big brake kit is really necessary? Could I just get a agent 47 brake cooling kit, and use a better pad compound?
2. Tires and rims. This is a very grey area for me. Is it possible to run a lower profile tire on a 17" rim? I worry that too small of a tire diameter will mess up the abs operation. Can you guys also give your thoughts on the "best" street tire/rim combination? I am on abit of a budget, but would like a nice light weight wheel/tire combination.
3. Suspension. While I would LOVE a griggs setup, I simply don't have that kind of money. I have searched the forum for opinions, but I guess I like to hear things from "the horse's mouth" so to speak. I plan to open track my Mustang as often as possible, but still be able to drive on the street occasionally. I am considering Pro-Kit, and Steeda Sport and Comp. spring sets. Please chime in on your thoughts about which would be the "best" for track usage. I am leaning towards the steeda springs, because I find that I tend to ride up on the curbing, and am worried that I may bottom out with the pro-kit. For sways, I think I will go to Mr. Strano for a set of adjustable front/rear bars. Koni yellows look like good shocks. Again, feel free to comment.
4. Weight reduction for a street car. I wish to keep stock appearing interior, (pl, pw, ac, factory stereo, good stuff . What can you guys recommend I do to save weight? How much weight could I reasonably save? My car is currently 3660 with me (160lbs) and 1/4 tank of gas.
Whew! That was a doozy. Thanks for listening guys.
